denoyan
- marquette, mi. usa
So, I guess the consensus is that per NEC, there is no minimum height on the panel. I wouldn't have a predicament with this job if I wasn't replacing a fed. pacific panel in an A-frame home. The existing panel which is around 10" wide, has 4" of clearance on the left side to the tapered A-frame roof & about 4" to the right where the left entry door frame is there. To get the wider square-d 100 AMP box in, I have to lower it because of the obvious A-frame tapered roof & close entry door. Access is easy but I'm wondering if the left & right side clearances are acceptable?
Thanks!
Thanks!
