rookie4now
I have a 6 unit building where the insurance co. is requiring fuses to be replaced with CB. There is a 125a service disconnect then a gutter to 6 meters with 30a disconnects. Theses are fed to a 2 circuit panel in each unit. There is one 15a circuit and one 20a circuit in each unit. There is 240v at the main disco but each unit has only 120V.
Here is the problem. There is currently only two #12 wires running to each unit. This is the feed from the disconnect to the 2 circuit sub panel which each unit has. They are currently protected with a 30a fuse. When we change the disconnects over, it is my understanding that 230.77(b) will require a minimum of 30a service as the units have 2 circuits. Since the wiring from the disco to the unit is #12, this will be a problem.
Am I correct about the 30 amp requirement? Is there a requirement that each unit has to have 240? Is the existing installation grandfathered in even if we change the disconnect to each unit? (notice how I am grasping at straws).
Amazingly, there are no tenant issues regarding blown fuses etc. as the units are very small. the owner just wants to do what the insurance co. is requiring and has not had any luck looking at other insurance companies.
Any thoughts, suggestions?
