ProjectDelta
- Michigan
- Electrician
Friday at work I was working on a large VFD swap out. Before powering it down, I measured the distance between the line feed pipe (1 1/2” rigid) and the load side conduit (also 1 1/2” rigid) to match the existing knockouts on the unit which both pipes penetrate the bottom. When I put my tape measure across the two conduits, there was a very tiny arc occurring every time I touched the conduits with the tape measure. Anyone have any theories on why this is? They ground the hell out of everything where I’m working so this is baffling to me.
