Just added 12 panels to an old 34-panel system. New and old are different make and size panels. Also, old Poly vs new Mono.
Despite my calcs before i started job - after installation the actual measured V is quite different from expected.
I just measured 467VOC on both the original circuits. (2 @ 17 modules, 180W each) 6,120W
I also measured 438 VOC on the new circuit. (1 @ 12 modules, 310W each) 3,720W
old vs new string: 6.6% higher Voc TOTAL: 9,840W
They all parallel to an old transformer based SMA SB US inverter. Single MPPT.
Was expecting matching Voltage.
Actually i only focused on Vmp matching, not Voc, for efficient MPPT tracking and operation.
(unfortunately have not measured operating V yet, all I know is actual Voc is off more than expected)
Questions:
1. Is this V diff. workable? Is this a problem? How much efficiency loss?
2. Is it possible that the old modules will drop at a higher rate from Voc to Vmp, than the new modules? This could close the gap between V-operating of old and new a bit.
Using the values from their spec sheets, the ratio of Voc/Vmp does indicate factors of 1.26 and 1.21 respectively.
3. What would you do?
4. Perhaps remove one module each from the old strings of 17?
2 strings of 16 at 440 Voc would result. (16/17 x 467Voc)
Not happy about nixing two good panels.
Here, the question is: what produces more power? All panels intact but producing the disparate V above
vs
removing 2 modules and losing the 2 @ 180W.
Adding a 13th new module to the new string of 12 is not an option. No good room for it.
Questions:
vs
