or they just changed their minds
I have a service on a house that will be fed from the garage, originally I was told the service was no longer going to be overhead, changing to underground.
I ran 2" PVC from the panel to a point outside the house awaiting the underground.
That has changed back to overhead, it will be 4 wire feeders (the house panel will be a sub panel) the house is already sheet rocked, so replacing the PVC would be difficult, but not impossible
my concern is, running 2" IMC through the roof, will the PVC handle the weight of the IMC
I am planning to put 2 or 3 stand off straps to help support the IMC
running the IMC, I now have a bonding issue with it, not sure of the best way to bond it, was thinking of a split bolt off the overhead grounding conductor to a pipe clamp on the IMC above the roof line
house is under the 2006 IRC
any ideas or suggestions?
Thanks
Thanks
