carter3933
- North Carolina
Brother-in-law called me to come fix his problem. He had attempted to replace a ceiling light fixture and a dimmer switch for that light. He was replacing the dimmer switch with a simple switch. He lives in a two-story town house.
When he turned on his breaker none of the lights on the second floor worked, which was were he was doing the work. The lights on the second floor was on a separate breaker.
What I found in the box in the ceiling was the usual -- 2 blacks and 1 white (going to switch) tied together, three whites w/ pigtail, and the black from switch.
With breaker on and wall switch on, found no voltage between black and white, but had 120 V between black and ground. Joints had tape on them, no wire nuts, so removed tape on white wires and found they had used crimp connectors on them. I cut the wires to measure to each one.
One measured ~92v to black, the other two 0v, but increased to about 90 when some of the other switches in other rooms were turned on.
Checked service to verify good connection on neutral wire, it was good.
I had to leave, good thing they wired the receptacles on different breaker. These Town homes are probably 20 - 30 years old. I plan to go back tomorrow.
Does anybody have any clues or suggestions?
Thanks,
Ron
Thanks,
Ron
