Hello, need some advice. I was helping a friend change his electrical service and I removed his electric meter. It is an older style meter and it is a ring type. I really only worked with ringless meters til now. Anyway, when we were finished, I attempted to put the old meter in new meter base and was unable to put the outer locking ring on the meter. I removed the inner ring (wasn't thinking) and found out this was the tamper ring that holds the plastic front dome onto the meter. I was able to put the meter onto the meter base with the outside lock ring but the plastic dome is a little loose. I'm not sure what poco will say and how much they will charge for a new meter or tamper ring. Unfortunately I cut the old inner ring off and no longer usable. Now it's damage control. Any suggestions? Poco is First Energy. Thank you
