Mixed voltage ratings
Brandon Loyd
Inside a 240v BCP, I found low voltage wiring ran to CT's to monitor the panel. But the low voltage wiring is only rated for 24 volts. I thought it was legal to mix voltages in a shared enclosure, as long as all wire is rated to match the highest rated voltage wire in that enclosure. Am I right, or is this a legal application?
