Can you use a 10-AWG neutral on a 3-pole 30A circuit wired with 8-AWG?? So the end result would be Twist-lock receptacles would have 8-AWG hots and a 10-AWG neutral on said circuit..You can use 10 or 8 so... Can you mix different wires sizes on a circuit if both sizes are ok in there own right???
Thanks in advanced.
Thanks in advanced.
