- Tennessee NEC:2017
- Semi-Retired Electrician
Other than looks, do you see anything wrong with using PVC to replace a RMC nipple?
I have to replace an outside MDP and if I can't find the same size panel I will have to change the RMC nipple between the panel and meter.
I went to a service call the other day for partial power. I found they had a bad main breaker. I couldn't find the breaker locally, and the bus was pretty corroded so I recommended replacing the panel. The owner of the building couldn't be reached for a couple of days so I didn't know for sure if he would let me do the job. I just found out that he wants me to do the install.
Anyway, I measured the panel and took pictures, but forgot to measure the length of the nipple. The place is a long drive from me and I don't want to drive there then have to come back to get a different size nipple should I need to. So I thought I would just use a piece of PVC to replace the RMC nipple, and I can cut the PVC to the size I need.
