Motor A was fed from emergency power circuit (480V)
Motor B was fed from normal power circuit (480V)
From one control panel, we run (2) separate low voltage signal wiring to motor A and B starters, control panel is powered by 120V emergency power circuit. Will we mix two signal above wirings in same control box violate NEC-700 (separate normal and emergency circuits)???
