drb7speed
New member
- Lexington, KY, USA
An Electrical Engineer was specifying wires for our circuit, running in cable tray.
Since he needed higher ampacity, he chose to use SRG (200 deg C insulation) wires.
"Manufacture's rating was 493 amps".
The problem that i have is that this cable tray is shared with thhn cables, 90 deg C insulation.
I am concerned that the thhn insulation we get damaged by the heat generated by the drg wires.
What does the NEC code say?
i found a section that said you need to use same insulation for each phase, for a single circuit, but
nothing about adjacent circuits...
