jt700
- Waltham,MA
I've been asked to replace a small exterior meter socket and house panel in a condo complex. The meter socket and panel are connected by an offset nipple.
The meter socket is a 100 amp underground socket. The existing panel is a 8 circuit MLO NEMA 3R panel which is fed with a 100 AMP Breaker which is plugged into it (As a result there are 6 Remaining slots). The lugs are not in use.
Is it code compliant to feed the panel in that manner?
