Re: Mobile Homes
Worm, are you aware that there is a separate article for manufactured homes, Article 550? Essentially, they only have to comply with this article, as opposed to several of the sections regular dwellings have to comply with in earlier chapters.
I was struck by this fact when observing some of the goofiness in my own manufactured home. Wall spacing codes are different, as well as others.
I'd imagine if you were to look at some of the code violations you see, you'd see they are permitted by Article 550.
Also bear in mind that the structure must conform to the code in place when it was built, and where it was built, which is usually not now and here. My home was built in '99, presumably under the '96 code, in Nebraska; and wasn't planted in the ground until November of 2001 in Colorado. So, when I became an electrician in 2002, I saw many "violations" that weren't.
Why the NEC is content with more lax restrictions on houses of questionable construction is just a question for the ages.
