chevyx92
- VA BCH, VA
Scenario, existing mobile home with a 100 Amp meter capacity feeds a pedastal that has a 50 A 120/240V receptacle. Customer wants to upgrade service to 200 Amps and have a disconnect outside which will feed a 200A panel inside. I told them this is overkill but hey they want it, plus they are getting a tankless water heater but that wont pull more than 50 amps. I still say the 100 amp service is fine. This is only a like a 10' X 30' mobile home. My question is do I need to leave the 50A receptacle pedastal outside if Im going to have a more permanant setup, PVC from outside disconnect going underground then coming up into a panel inside? Or can I totally delete that pedastal? Also do I need to have a main breaker type panel inside the mobile home if I will have one outside mounted on the pole within 30'?
