Re: Mobile homes
My very first electrical job was in a mobile/modular plant.
I had visited other plants, seen videos of other plants, and talked with guys from other plants.
It seems to me that they all follow about the same routine.
There is an in-house HUD inspector (sometimes 2) that inspects the entire manufacturing process. They are not at all areas at all times. Thay kind of 'float' around looking at everything.
Once had one tell us that we pulled the wrong wire for an electric furnace. his reasoning was because the wire was black and it was supposed to be gray. It got painted black when they sprayed the undercarriage.
There are many stages of wiring a mobile/modular.
It all starts in the bottom. There is a 1-2 man crew that wires the bottom, crew that wire the walls, crew that wire the ceiling, crew that install devices, guy that does the service, guy who does the dielectric test, and more...
The devices that the above posters mention do not require a box. They are UL listed for the use. I personally think that they are junk and have seen many problems with them. They use the same principal as backstabbing a standard device only you use a tool to press the wires into the back of the device and snap on the cover. Then install like a typical nm old work box.
AMP corp. from Harrisburg, PA (among others) make a listed in-the-wall splice for manufactured housing. They can't be used anywhere else.
Anotherthing is they usually use tek screws to install the bonding lugs, where we would drill a hole and use a bolt and nuts.
