Devin A. Pratt
- Upstate New York
Who is responsible for rough in inspecting mobile homes when manufactured?
Are the following findings common for these homes?
Recently I was called for power loss at a double wide mobile come set in on a 2 foot foundation/crawl space. This home is approx two hours from my home base the HO had three electricians attempt to trouble shoot their problems with no success.
This home has four bedrooms, 2 baths, 2 living rooms, office, dining room, Kitchen and utiliy room.
Panel 12 space cutler hammer
Findings:
15amp OCPD 14/2 NMB wire Feeding.
9 outlets including the Master Bed, Master Bath GFCI,Living Room, Utility Room and Heat Tape Outlet under home in crawl space.
7 Areas of lighting Master Bed 1 light, Master Bath 2 lights and 2 fans, Master Closet 1 light, Utiliy 1 light, 1 coach light and kitchen 1 light.
Problems Found Other than overloaded circuitry.
Open nuetral in the outlet under the home and pin hole in the insulation of positive conductor touching the ground in the switch for the master bed light.
None of the devices on the circuit were properly terminated.
Findings:
