Mocp
codequestion
Banned
MD, USA
Can someone tell me the MOCP of model k-A1-D250-G10 MUA and also for BDU20K EF? I tried but captivair does not have mocp.
Sent from my SM-G935U using Tapatalk
Well the "D250" comes up as a gas fired burner unit with no fan, so why would there be an electrical MOCP on it?
The BDU appears to be a different make, K-tech hoods, and because it appears to just have one motor, you would just use the motor nameplate info.
MCA and MOP are on the wiring diagrams. lower right hand side.
If you know the project number/ job number, you can call your nearest Captivair office and they will tell you.
Their is a fan d250 at least on sechdule shwon on drawings.
The A1-G10 MUA is a 10 inch blower filtered makeup air unit. There are about 30 possible motor/ voltage possibilities. The D250 is not listed in their motor reference.
As stated above call with the project/job number and they can tell you every thing about the unit.
