mod metering/1600 amp buss
augie47
Tennessee
does anyone know of a mfg. that can supply modular metering with 1600 amp buss, 6 400 amp meters ?
The only one I've ever seen with my own two eyes was ITE, so that gives you an idea of how old that was. I think very much that anyone will build anything you want. The trouble, as mentioned, will be getting it approved by the PoCo. You're going to need to run any preliminary shop drawings from the vendor past the PoCo for approval first, I feel sure.
You can do this with Square D no problem. The only thing that can be a pain sometimes is POCO approval, although it is usually fine in my neck of the woods.
ITE use to build 4000 amp boards with what ever metering you requested 400-800 amps. This was in the Washington Metro area PEPCO was the utility provider.
