IMO these partitions are not part of the building structure or finish.Accessible (as applied to wiring methods). Capable of being removed or exposed without damaging the building structure or finish or not permanently closed in by the structure or finish of the building.
Sure, it comes from hereOriginally posted by jonesm:
Iwire ? Thanks for the response, but I couldn?t find where ?The wiring method of the outlets only has to be accessible? came from. Could you elaborate?
Keeping in mind that the NEC is a permissive code and that I am unaware of any further restrictions on the receptacles themselves that above section is it.314.29 Boxes and Conduit Bodies to Be Accessible.
Boxes and conduit bodies shall be installed so that the wiring contained in them can be rendered accessible without removing any part of the building or, in underground circuits, without excavating sidewalks, paving, earth, or other substance that is to be used to establish the finished grade.
Exception: Listed boxes shall be permitted where covered by gravel, light aggregate, or noncohesive granulated soil if their location is effectively identified and accessible for excavation.
Accessible, Readily (Readily Accessible). Capable of being reached quickly for operation, renewal, or inspections without requiring those to whom ready access is requisite to climb over or remove obstacles or to resort to portable ladders, and so forth.
