Modular meter socket grounding
joebudd
Ok. Here is the deal. I have a 1200amp 3 phase main breaker. 208 with a nuetral. The nuetral will need to be grounded for the 1200 amps at the nuetral terminal in the main disconnect box correct? Now there are 8 200 amp modular meter sockets. 2 meters in each bank. total of 4 banks. each bank has a ground block that is mounted with 2 10/32 screws, paint not scraped. Do I need to run a ground from each block, total of 4, down to the ground rods? 4ga ground for each be fine? Or tell me what you would do! Thanks
