electrofelon
- Cherry Valley NY, Seattle, WA
The system has string inverters so no module level monitoring. It would be super easy to just short the leads of a discolored and a non discolored one and clamp it and compare the values Overall output seems to be fine.How's the power output from the array? Can you check the individual panels??
Any possibility there's water or condensation getting under the glass?
Everything looks normal from the back. I did not use a thermometer, but temperature feels all uniform at the back.What do the bottoms look like?
I suppose it's possible, but the irregular shape and sharp boundaries suggest something physical is going on. I vote for delamination and water intrusion.It could also be a light refraction effect that has no impact on module production.
It may not be a problem. Glass is somewhat permeable to O2 and Si forms a thin SiO2 layer when exposed to O2. That could have refractive index effects (like oil sheen on water) that would not affect production. Can you see me waving my hands around?I suppose it's possible, but the irregular shape and sharp boundaries suggest something physical is going on. I vote for delamination and water intrusion.
Are you sure it isn't mineral hardness on the surface of the glass? Wipe an area down with vinegar and see if it can dissolve it.
It is definitely under the glass.I have seen similar looking modules when a customer tried to wash their modules with soap and did a poor job of fully rinsing them off.
That is what I figured, it was during the manufacturing process.I was wondering if the circular spot was related to a suction cup being used at some point. Maybe during manufacturing or maybe later.
