You might look a "beam detector". It has a transmitter and a receiver and shoots a beam between them. When there is enough smoke the alarm goes off. This would not be as sensitive to moisture as a standard smoke detector.
Yes, it sure could, but I am not sure that they are really getting fog in the garage. I think that the dampness and condensation within the existing detectors that comes with foggy damp days is the issue, but I could be wrong and if there is significant fog within the structure the beam detector would see that as smoke.A beam smoke could be affected by fog though...
Jim
Is there any practical way to add a little heat? If you can get them above the dew point, you will not have condensation. In electronics, it used to be common to use a PTC device to keep crystals (frequency determining devices) at a stable temperature.Is there such a thing as this.I have a parking garage that has smoke dect. they are always going into alarm in wet weather days ie fog day, cold day when they sweat they are install on concret.any help would be great.
thank you
roger villegas
