philelectric
I was contacted by a customer with a problem with moisture permanating the exterior walls of his 2 year old home. The construction of the wall is traditional stucco over "Flexcrete non autoclaved aerated concrete block". The interior layer is "American Clay". The house is wired with NM cable and plastic boxes that are cut into the block then plastered over with clay. The problem is the moisture is so bad that you can see streaks on the walls where water has literally run down the walls. In several areas there are switches and receptacles with streaks around then. He and I are concerned about the safety of this condition. Short of moving out can anyone think of the safety to the homeowner of the devises staying damp and a short term solution? The bedrooms are AFCI protected but there are areas just on standard breakers. And of course there are lawsuits with the builder and manufacturer of the concrete block.
