I need some help. I am being asked to remake a system for testing ac voltage/current sources. One of the tests is to determine the timing of events. Specifically, I need to determine the time between signal input and loss of AC.
The device under test is a Doble F2250. There is a relay timing function that I am calibrating/verifying. The issue is that the Doble produces an AC signal that (according to the manufacturer's data) switches off at the zero crossing. I have to be able to capture the moment when the AC is switched off. I have been struggling with a method for some time. I have considered a PT/rectifier setup as well as a Rogowski coil. I have even considered using an derivative op amp circuit figuring the change in slope from the negative to a fixed 0 would be something I could pickup, but the duration of the resulting pulse is likely to be very small and possibly not noticable even for the 40MHz microcontroller I will be using for the brains under the hood. The bad part is actually not monitoring for the loss of AC but rather the timing. I have to get this within a few uS. I have not actually mocked anything up at this point because I am not certain of the idea's soundness.
Has anyone ever had a need to do this? Does anyone have any ideas as to hoe to pull this off?
