Moorepower cant spell
electricmanscott
Boston, MA
Re: Moorepower cant spell
Strike two! Seriously, in general yes if you are talking the underside of a house. There really needs to be more info to get a more accurate answer.
tom baker
Bremerton, Washington
Master Electrician
Is it a service, feeder or branch circuit?
Also take a look at section 338.10 uses permitted
I would rather show you where to get the answer then give you the answer. Then if its still not clear, please ask!
Tom
It is a service. do you need more details
russ
Burbank IL
If installed to code, I can't see why you would not be able to put it in a crawl space.
iwire
Massachusetts
The info I think we really want to know is this really service conductors (main inside) or a feeder (main outside)
If this is a service conductor then most places will not allow you to run more than a short distance inside before you get to a main disconnect.
Inside the crawl space would be considered inside the building.
[ December 11, 2003, 08:23 PM: Message edited by: iwire ]
hurk27
Morepower If there is fuses or a breaker protecting this wire then it is a feeder and would be allowed in the crawl space but if there is no protection the it must terminate as soon as it gets in side.
