More Efficient Design with Load Shed?
Designer69
Please see attached pic.
Design option 1 requires 3 panels and no load shedding. Option 2 requires only 2 panels but load shedding of 60 loads.
In this particular application, which is the better design?
I guess if it is really feasible/possible to shed 60 loads, then option 2 could make sense but you'd still need a main service disc. sw. vs. a panelboard so I'm not sure there's really any cost savings in option 2.
kingpb
SE USA as far as you can go
Engineer, Registered
How are you going to load shed the loads in Option 2 in panelboards? Shunt trip? Then who will have to go reset those breakers.
Option 1 seems much simpler to accomplish and operate.
Designer69
Ok thank you. I wasn't sure what current load shedding technology is capable of. Thought maybe it's possible nowadays to just program and shed as you please. Guess not haha
I did design this job with option 1, just wanted to check here to make sure I didn't provide a less efficient design.
Thanks
