I am new to this board. I am a licensed contractor in good standing in CA.
I need some help. I just finished installing a 240/208/120 volt three phase 45kva transformer to supply support stations for a manufacturing plant with household current. The brake room has a dishwasher and garbage disposal on a dedicated circuit that is protected by a GFCI receptacle. Before writing this I read what many have wrote on this subject and true to form this device will open the circuit if the test button is depressed but not when a test plug is used. I roped the structure myself using MC cable [and anti-short bushings] so I know that all the grounding is done to code. It has all the signs of an EGC problem, but I have no idea how to correct this. The soil in the reagon is too alkaline to use a copper water line as a grounding electrode so I can only rely on a grounding rod for a grounding plan which is about fifty feet away from the receptacle.
Any ideas how to correct this problem?
Thanks in advance.
Thanks in advance.
