bjp_ne_elec
- Southern NH
I just did a search and couldn't find something specific I'm looking for direction on.
This old house that I took the previous pic of that "brass" cap. There is an old fuse block - the ones that had the fuse in line with both the hot and the neutral. There was a Romex just run to it from the new style panel (looks like they may have been added 4-5 year ago) - but whoever did the work just simply spliced in to the existing K&T in open air just putting wire nuts on what would be the line side of the fuses. I'm not sure why they just didn't run the Romex's hot and neutral to the line side of the fuse blocks - but I'm not even sure that's legal. Is it?
Even if it's not legal, it would be safer than having two open air splices with no JB.
Now my next question. If you had K&T that was running out to parts of the house, is it legal to feed the existing K&T with a new Romex. I'm asking this question, as I had no experience even going through my apprenticeship with K&T. As I said in the previous post, the house I grew up in had it, and my father re-wired it - but I was "knee high to a grasshopper" when he was doing this. So, could one the proper size Romex to a non-metallic box and then feed some existing K&T that was still existing in an older house?
I did find posts that covered capping off some ends of K&T, where some part of the circuit was eliminated. This covered removing "downstream" wiring. But my question is dealing with the other end.
Thanks
Thanks
