Alien Legs
- Vermont
- Master Electrician
My plan is to install a meter main pedestal within sight and 50 feet from a home here in Vermont.
The questions I have are...
1. Do I need to have another disconnecting means located on the home if the meter main is located within 50 feet and within sight of the home?
2. Do I need to separate the neutral and ground wiring at the meter main pedestal?
3. I know I will need ground rods at the meter main pedestal. The home will have an insulated foundation and slab so does a ufer ground make sense because I know ground rods are only to be used as supplemental? There will be a well so there will be no metal water line ground possible at the home.
I have been asking around to inspectors and other electricians and get different answers.
There are no permits or inspections required here but I would like to install systems properly to code.
Thanks
Thanks
