EEEC
- Benicia, CA, USA
I know that the rule of thumb is to upsize your wire gauge for every 200ft in length. I have a situation where I am wiring a space that is approximately 120 ft by 50 ft. If I run a feeder from the panel to a switch (approx 120 - 150 ft) and branch out to 12 lights, I will be using well over 200ft "worth" of wire. I've never had to take this into account before. Does the rule apply in this situation? And if so, can I run a 10-2 to the switch and then run 12-2 to each light?
Thanks in advance.
Thanks in advance.
