tomray1952
New member
Ref 16.1.8 in 1997 edition of industrial machinery states that "not more than two conductors shall be terminated at each terminal connection." In 2002 version Chapter 14 doesn't specifically address this point at all. We use 600v or less 3 phase power distribution blocks with 12 openings per pole on the secondary side to supply line sides to branch circuit breakers. Assuming correct ampacities are followed for the wire, is it acceptable practice to put two wires into a single hole / pole connecting point on the distribution terminal block ?
