sfav8r
- San Francisco Bay Area
OK, so a friend of mine calls and says he can't get his pond pump working even after installing a brand new pump. He tells me the steps he's taken and I can't really make sense of ot so I tell him I'll head over and take a look at it. I won't go into all the steps I took, but this is one of the strangest troubleshooting calls I've ever had. Here is the situation:
There is a GFCI protected outlet about 6' from the pond. It is fed from a dedicated circuit. When you plug the pump into the GFCI, it will run for about 2 seconds then shut-off. If you unplug it and plug it right back in, it will run for 2 seconds again. If you take the pump, put it in a bucket of water, plug it into any other outlet it will run all day. If you take anything BUT the pump and plug it into the GFI by the pond, it will work perfectly. (no really, I saw it with my own eyes). I monitored the voltage at the GFCI by the pond it it is OK at all times and the GFCI never trips.
Now here is what I found out and what I find to be really strange. Because of the weirdness described above, I decided to try putting the pump in a bucket and plugging it into the GFCI by the pond...violla, it works perfect...no shutting off. If you take the pump out of the bucket and put it in the pond, it immediately stops. Thinking there might be something odd with the water in the pond, I put the pump back in the bucket (it came back on). I then placed the bucket into the pond and the pump in the bucket immediately shut off even though it was still in the fresh water in the bucket. So, I think I am on track when I conclude that the issue only surfaces when the pump is grounded via the water in the pond. To try and confirm this, I put the bucket and pump on the walkway near the pump. It worked fine, then I ran a wire from the water in the bucket and touched it to the wet ground near the pond and again the pump shut off. As an experiment, I ran a ground wire from the electrical box to the water in the pump and the pump continues to run fine. So, my theory is that there is some stray voltage or something in the ground near the pond that makes the auto-shut-off in the pump decide it needs to turn off. I came up with the idea of isolating the circuit, so I used an isolation transformer between the GFCI and the pump and now it will work fine, even when submerged in the pond water. OK, I know all that is strange enough, but what I found out by accident is even more strange. I may make a youtube video of this because if I hadn't seen it myself, I'm not sure I would believe it.
When the pump is plugged into the GFCI outlet and submerged into the pond water, as I mentioned in the beginning it runs 2 seconds and then turns off. For reasons I cannot explain, if I take a 30' extension cord and plug it into the other outlet on the same GFCI. even though there is nothing plugged into that extension cord, the pump will start running. I tried a different extension cord and it will not work. Only one of the three extension cords I tried worked. The difference in the cords is that the one that worked is the type that has the wires twisted around each other and the ones that do not change anything are the type that are just individual wires that parallel each other. The only thing I can think of that even comes clsoe to making sense is that the cord with the spiraled wires when plugged into the other outlet (parallel to the pump) is somehow inducing a "coil" effect or something. I am really intrigued by this problem. as I mentioned, I have it "fixed" but I'd really like to understand what is going on here.
Any ideas?
Any ideas?
