Electric-Light
I've been checking on this vacancy sensor (basically occupancy sensor that can not be set for automatic on).
You're supposed to push the button to turn the light on, the the light is turned off by timer or by pushing the button off with no permanent-on override.
If it's shut off by the sensor, it will turn back on again if there is a motion within a grace period. This isn't supposed to happen when it is turned off manually by the button.
This sensor re-triggers on motion after a manual off sometimes and I have been able to duplicate it several times. Checked connection and everything was good.
Took it out, bench test it and I can't get it to duplicate.
Any idea?
Any idea?
