sparkmatic
- California
- Electrician/Instrumentation
So /we have motion sensors through out my site that power T5 fixtures single lamp, that are 240V to ground. The sensor is rated for 120/230 (single phase), 277,347. I do not see any issue with the voltage but for some reason from what I have found out that this is not the first time the sensor smoked on someone. For me it happened after I restored power, the lamps came on for about 10 seconds then the sensor let loose
I then did some checks found nothing grounded but replaced the wiring and lamps (these are fixtures that come pre set up with cables that plug in either side of each fixture (encapsulated)not my choice just whats here.
After the rewire the lights work and have worked for a few days now. Hope this makes sense.
My main question is has anyone had this kind of issue? I don't want to put the manufacture out there as it may not be their issue just don't see an issue that should cause these smoke (violently)
Thanks
Thanks
