muscleup123
I went out on a trouble shooting call where a commercial bathroom motion sensor was installed, with a florescent light, and fan. In the auto position the light would not always come one, and the fan would be running at a lower rpm. I changed the motion sensor, like for like, but had the same problem. The light and fan come on fine in the ?on? position, so I checked out the switch instructions, and it recommends only magnetic start magnetic ballast to be used with this switch. I assume the ballasts are the problem here, and that I need to find a better commercial grade sensor. Does it sound like I?m on target, and if so will I be able to find a sensor that will work more than one type of ballast? Thanks.
