Motion sensor question
JJWalecka
New England
I need to be install motion sensors for this type of antique fixture. What would you suggest. I was thinking about the sensors the lamps just screw into but I'm not sure the sensor will work through the frosted glass nor would the glass globe fit over the sensor correctly
Appreciate your time
The most common way to do it is to put one in the wall switch. If that does not work for you, you may need one in the cieling. The key word when googleing is 'Occupancy Sensor' Their are many different types.
But again the fastest is to put one in the wall light switch.
