tonyou812
- North New Jersey
What would happen if you hooked up two motion sensors in parallel with a flood light? I have a customer that wants a set of lights to go off from differant locations outside his house
tonyou812 said:What would happen if you hooked up two motion sensors in parallel with a flood light? I have a customer that wants a set of lights to go off from differant locations outside his house
I moved Nafis post to a new thread....nafis said:I have two of 180w flood light on (dawn to dusk) sensor, planning to install receptacle for Malibu Transformer on the sensor load side. Sensor rated for 1800w got it from HD. Load on transformer is 300w low volt light. Now the question is .will this work and what problem might i encounter beside the dawn to dusk issue.
Thank you
