Motion sensors
Ken9876
Jersey Shore
It's been a while do those Hampton Bay motion fixtures have the option of a master and slave setup? I need to control two garage lights and was going to add a remote head but there isn't much room around the garage door.
LarryFine
Henrico County, VA
Electrical Contractor
The instructions should say so, and will likely have a wiring diagram showing how. You'd basically run 3-wire between them, similarly to smoke detectors, and join the two sensor red output wires.
goldstar
New Jersey
You shouldn't have a problem. Just read the pamplhet and make sure you don't exceed the wattage capability of the unit. Also, from what I remember about these devices the red output wires are pre-crimped under the w/p cover so, you'll have to uncrimp those wires and re-splice.
