Might not be a good idea to install a Motion sensor in the CAR especially on the ceiling. Depending on how big the return grill is, vibration can set off a motion sensor due to resonance. Second, the sensor may need a clean field of view to cover the area being monitored. I take it this is for security reasons to turn on a video or an alarm?
There are alternate methods that can be used...such as an IR sensor that is available as a fake wall receptacle. The IR includes an X10 unit that triggers the remote monitor through a branch circuit as a power line carrier that connects to somewhere else in the house for a recording or alarm unit. You can use an RF transceiver also. These methods eliminate running LV through the house by locating the devices at standard 120V receptacles that are not on AFCI lines that need filtered coupling.
