Motor 430.36 mike holts 2017
Djelite
Ny
Hi is there a way i can find a copy of mike holts 2017 430.36 example from his understanding the nec volume 1 2017?
I don't have his book available but are you sure that 430.36 is the correct section number?
430.36 Fuses — In Which Conductor. Where fuses are used for motor overload protection, a fuse shall be inserted in each
ungrounded conductor and also in the grounded conductor if the supply system is 3-wire, 3-phase ac with one conductor
grounded.
Do you want to have this for your own reference, or to either use in material you are using internally or as part of something you are selling or giving away?
If the latter, you can contact the office to see if they will either give or sell you permission to use it with proper attribution.
