ramihamdan
- indiana
- Electrician
A three-phase motor draws 45 amps at 240v. How much does the same motor draw at 480v three phase? What would be an equation for this theory problem.
Mathematically, or if you modify the load for the new voltage, yes.Like garbo said just divide by 2. Double the voltage 1/2 the current.
Yes I'm stating the obvious that the motor was designed for dual voltage operation otherwise a 240 motor at 480 volts wouldn't run too long.Mathematically, or if you modify the load for the new voltage, yes.
As I said the last time this was asked, the OP said "the same motor."
