G goldy09 Member Jan 16, 2006 #1 If a three phase motor is fed by a parallel feeder, two cond. per phase and ran in seperate conduits what should I know about parallel feeder conds. Motor is 3p 150hp. 40d. C rise code g auto transformer start.
T templdl Senior Member Location Wisconsin Jan 16, 2006 #2 Re: motor calculation You never isolate the phases but run a set of phases in each conduit, that is if you run 2 parallel/ph you would run 2 conduits with one A-B-C in each conduit.
