The other day I was called out to a marquee (moving electrical sign) because of a faulting mechanical moving part. By accident, I hit a shunt switch that killed (opened the main) the power to the entire sign. Nothing major happened from activating the shunt, except the embarrassment I had to endure of having to call someone out to unlock the main disconnect enclosure, to through the switch closed, and turn the power back on to the marquee.
The following day, the company that built the sign, E-mailed me back claiming the following;
?The motor (for the sign) is a giant inductive load, and when the field collapses on a big power dump (from activating the shunt), it's possible to injure the fuses to the point where they'll pop before the drive faults out. (They're a semiconductor based 'amp trap' current limiting fuse, and the semiconducting material can be partially fried to the point where it will blow at a lower current limit level on the next high current event).?
My question is;
Is this true? If true, can some direct me in the direction, information or understanding on motor collapsing fields and possible over currents it can cause?
My question is;
