Motor contactor with electronic overload relay
I am somewhat new to the latest technology in motor controls. I have a customer that has a metal shear that was converted from 480 volt to 240 volt 3 phase. It pulls about 9 amps and now the electronic overload relay does not dial up high enough for the FLA of the motor on the lower voltage. Somewhere I thought I seen a motor start contactor with a electronic overload relay that is DIN rail mounted and it was quite small and compact and I think it was all one unit by that I mean I don't think you could detach the overload relay from the contactor itself. Possibly made by Schneider Electric. My control box on the machine is kind of small and I did not really want to go with a typical motor starter with the heater overloads. Does anybody have some suggestions on what would be the most economical or some links to a product that I could use. Thanks
