Hello,
I am building a motor control center for a facility remodel and have a question about disconnect means. This MCC will be fed from an 800 Amp 240volt 3ph breaker in an MDP which is located on the outside of the building that will house the MCC. Does my MCC need a disconnect means inside for the entire panel, with a handle through the door? I am using a 3 door enclosure so the door interlock poses some obvious problems and I also do not want to have to shut the entire MCC down just to reset one starter. Inside the enclosure each motor starter or drive has its own breaker. The panel will have to pass a county electrical inspection. I am trying to avoid using a main breaker inside due to cost.
Thanks
Thanks
