We have a client with an existing MCC and they are looking to upgrade/modify. The motors run 24/7, and only 2 groups of motors need to have A start before B. All of the motors are 208V and no larger than 10HP. There is an alarm system involved incase one of the motors fails.
I have 2 primary questions...
1. Is a motor control center necessarily needed for continuous on/ manual off operations, and all of the alarm equipment? (pretend you are the client, would you want one)
1.a. If you don't think a MCC is needed, what would you use to trigger an alarm situation? Would you stick with a motor contactor is an aux relay just eliminate the lights and switches?
2. If an MCC is need, what manufactures are helpful with equipment selections? I can do all of the calculations of the motor starter and overload device, but our office has not had to design an MCC in a long time, I assume most of you will say Allen Bradly, i am curious if there is anyone else out there.
