Nardie
- North Augusta, SC USA
Recently I had a motor starter coil fail due to age, this starter has been in service since probably the 1950's. I contribute this failure due to age, however when performing an inspection of the cubicle I noticed that the control circuit voltage was 480 VAC. This is something that I am not use to, I am typically use to a motor control circuit voltage to be 120 VAC due to a control transformer. From reading the NEC it doesn't address the control voltage level, whether it be 480 VAC or 120 VAC. However, I believe the control circuit should be reconfigured with a control transformer with 120 VAC being used as the control voltage just due to safety considerations. I don't know of any code requirement to due as such, but would appreciate any opinions and/or suggestions on the subject. Thanks
