Here is the scenario- I installed a pool pump control panel that is listed by ETL. The pump relays installed by the panel builder are UL recognized components rated to 3HP@277volts. The largest pump is 3HP. So far so good... BUT the manufacturer prints on the side of the relays a lower rating- in this case 2HP. The UL file on the specific relay clearly indicates that the were rated to 3HP but may be marked at a lower rating.
Can these relays be used for a 3HP pump or a max of 2 HP.
Any thoughts would be appreciated as I am dealing with an inspector that insists they are maxed at 2hp.
Thanks- Greg
Thanks- Greg
