ptonsparky
Tom
- EC - retired
430.102 etc
I try to put a disconnecting means within sight of each motor. Yes, I know how far an inspector can see. 50'.
Ag projects so no inspector will see it until the lawyers get involved. The problem.
Do you go to the trouble of putting a disconnect near a motor that has no ready access to it? On an Auger 20' feet in the air. We build a support for them but it is a real PIA and expensive. Then add a control pole so everything else knows its Off. In this case each motor has a readily available PP at ground level.
Is that location considered "impracticable"?
